5 piece Renault ecu tool
  • skeuf
    • 484
    Pour ceux que sa intéresse il y a du stock ici
    [url]http://www.programatory.com/index.php?p895,renault-can-k-line-ecu[/url]
    Commande passez hier pour ma part
    • peug89
      • 249
      @naoufel28
      comment on fait skeuf pour identifier mexicain qui voulait me semble ?
      cdt
      • axor34
        • mai 2014
        • 132
        1 dispo l acheteur repond plus contact mp
        • Ludo307
          • 212
          A quoi sa sert lol ?
          • axor34
            • mai 2014
            • 132
            • EDC15C3 (both CAN-BUS and WIRE immo systems) - Read/Write EEPROM, Read/Write FLASH, Clear Immo Code
            • EDC15C13 - Read/Write EEPROM, Read/Write FLASH, Clear Immo Code
            • SIRIUS 31H - Read/Write EEPROM, Read/Write FLASH, Clear Immo Code
            • SIRIUS 32[N] (both CAN-BUS and WIRE immo systems) - Read/Write EEPROM, Read/Write FLASH, Clear Immo Code
            • SIRIUS 34 (both CAN-BUS and WIRE immo systems) - Read/Write EEPROM, Read/Write FLASH, Clear Immo Code
            • SIRIUS 35 - Read/Write EEPROM, Read/Write FLASH, Clear Immo Code
            • EMS3132 (both CAN-BUS and WIRE immo systems) - Read/Write EEPROM, Read/Write FLASH, Clear Immo Code
            • EMS3134 (both CAN-BUS and WIRE immo systems) - Read/Write EEPROM, Read/Write FLASH, Clear Immo Code
            • SID301 - Read/Write EEPROM, Read/Write FLASH, Clear Immo Code, Clear IMPACT DETECTED, Read stored mileage
            • SIM32 - Read/Write EEPROM, Read/Write FLASH from HD64F7055, Clear Immo Code
            • SAFIR / SAFIR2 / SFR200 (35 / 55 pin connector) - Read TMS374 EEPROM, Clear Immo Code (carruns without immobilizer code)
            • IAW 6R.20 - Read/Write TMS370 EEPROM
            • IAW 6R.30 - Read TMS370 EEPROM, Clear Immo Code (car runs without immobilizer code)
            • VALEO BII for ESPACE III - Read/Write (9)08AZ60 EEPROM, Read/Write mileage, Clear for Replacement, Read transponder data, Emergency Startup
            • VALEO IMMOBILIZER for LAGUNA I Ph2 (1998-2000) - Read transponder data, Configure, Reset to VIRGIN
            • INSTRUMENT CLUSTER for ESPACE III (1998-2002) - Reset odometer, Erase RF remote programming by instrument cluster connector
            • SIEMENS IMMOBILIZER for ESPACE III Ph1 (1996-1998) - Read/Write 68HC05B16 EEPROM, read transponder data
            • SIEMENS UCH for MEGANE/SCENIC ('98-'02) - Read/Write 705B32 EEPROM, Read/Write configuration, Learn Keys
            • LAGUNA II, ESPACE IV, VELSATIS, LAGUNA II Ph2, ESPACE IV Ph2, VELSATIS Ph2 - KeyCard Programming, Change VIN
            • MEGANE II, SCENIC II, MEGANE II Ph2, SCENIC II Ph2 - KeyCard Programming, Change VIN, Reset UCH to VIRGIN
            • INSTRUMENT CLUSTER for SCENIC II ('04-'08) - Wake-Up by CAN-BUS for repair or to check mileage, Change language and units, Change VIN
            • CLIO II Ph2, KANGOO, TRAFIC, MASTER, VIVARO, MOVANO (-'07) - Read/Write EEPROM 93C66, Key Learning, Change VIN
            • KANGOO I, TRAFIC, MASTER, VIVARO, MOVANO ('07-) - Key Learning, Change VIN
            • KANGOO II (2007-2012) - Key Programming, Change VIN
            • MODUS / CLIO III ELECTRIC POWER ASSISTED STEERING (TRW DAE/PAS) - Clear Immo Code, Change VIN by OBDII, erase DF002 from 24C16 dump, repair CRC (! UPDATED !)
            • MEGANE/SCENIC III ELECTRIC POWER ASSISTED STEERING (NSK DAE/PAS) - Clear Immo Code, Change VIN by OBDII
            • TWINGO III ELECTRIC POWER ASSISTED STEERING (JTEKT DAE/PAS) - Clear Immo Code, Change VIN by OBDII (NEW !)
            • LAGUNA III (2007-2015) - KeyCard Programming, Change VIN, Reset BCM to VIRGIN
            • LATITUDE (2010+) - KeyCard Programming, Change VIN, Reset BCM to VIRGIN
            • CLIO III / MODUS - Key Programming, Change VIN, Learn ECM in protected mode
            • CLIO III - Card Programming, Change VIN, Reset UCH to VIRGIN
            • MASTER III (2010-) - Key Programming, Change VIN
            • WIND (2010-2013) - Key Programming, Change VIN, Learn ECM
            • TWINGO II (2007-2013) - Key Programming, Change VIN, Learn ECM
            • TWINGO (2001-2006), LOGAN (2004-2008), SANDERO I, THALIA, SYMBOL - Key Programming, Change VIN
            • LOGAN, SANDERO, THALIA, SYMBOL (2008-2012), Duster (2010-2012) - Key Programming, Change VIN
            • MEGANE III / SCENIC III (2009-2015) - Card Programming, Change VIN, Reset BCM to VIRGIN
            • EDC17 / MED17 TRICORE EEPROM DUMP CRC - Reset EEPROM dump to VIRGIN, repair block checksums (NEW !)
